1 - 3 of 3 Posts
Im about to get rear ingall arms since my front lower arm is bent and it needs to be replaced. Might as well do the back to and just pay for alignment once.
I was wondering should i get the ingall front camber bolts? like will it make a difference. Also if so then how difficult is the install? If anyways has them, did they feel like the tires lasted longer?
You don't need camber bolts unless your lowering your car! If your not lowered at all, you don't need them for sure.
1 - 3 of 3 Posts
