1 - 9 of 9 Posts
hey guys,
i need a full engine gasket kit, well autozone and advanced have it but i wanted a better headgasket than it comes with.. they are also way over priced. Can i get like a copper headgasket? its preparation for the turbo setup. Anyone know where to get this??
Thanks
Andrew
copper doesn't have the best reputation for doing head-gaskets, as far as i heard, you can look into rpw gaskets, they are in 3 different width's...
Discussion Starter #6
ill do some more research on what would be the best gasket for a turbo engine, also i need the stock width gasket bc i have 8.5:1 compression pistons to go with that. if i cant find anything then i guess ill just have to use a new OEM head gasket. but i would like a more stable/ dependable gasket.
this is one of the last things i need for my turbo setup.
antiquity said:
arent the OEM gaskets double layered some bs and are very reliable?
Yes. The world would be a better place if all head gaskets were this good. Not much need to search for a 'superior' aftermarket H/G.
-BRR
1 - 9 of 9 Posts
