1 - 17 of 17 Posts
Im looking to get a tiburon (04-07). My price range between $7000-8500. Im leaning to a manual transmission because I think it would be fun to drive (don't plan on driving in to much traffic) and better on gas. I just don't know whether I should get a 5 spd or a 6 spd and what to watch out when buying from a private seller. I've been looking around this forum for a little bit and I heard to check the timing belt and clutch.
I won't be racing this car, just want a new car that looks nice and is fun to drive.
Just hoping on getting some insight on what seems like a promising car. Any help will...well...help.
I have the 6-speed, but 1st gear is pretty much useless and most people praise the 5 speed
I would look out for any aftermarket stuff the private seller has done to their car, the person I bought mine from basically ripped out a whole sub woofer system and left a crap ton of wires around the car all touching each other causing my battery to die on me.
alright 6 speeds had lots of problem i love my six speed to be honest but when i go F/I i am going to screwed cause 1st gear will be useless beyond reason... but like someone said in a thread a while back that The Tib is like a hot chick with a broken leg... Its sexy but not fast... manuals are funner to drive but if your going F/I with big boost i would go with an auto...
I bought my 03 with 79k on it for 6g after taxes but I would try and find an 05/06 Sexier Front ends... you could probably find one with 60k on it for 8500 or so...
http://www.newtiburon.com/forums/showthread.php?t=167600
couldn't of said it better :)
lol, if I lived near Annapolis I would probably check it out. Little higher then I was wanted to spend. I'm surprised you can't sell it, seems like a reasonable price for it.
Its actually an I4 lol. But um it all depends, if you want good gas mileage or plan to go turbo (which i know your not) then I would go for the 4 cylinder. But since you dont want to tune the car and want something fun to drive that is stock, I would say the v6 has a little more kick and would be more fun for you.
All in all
I4 = good gas mileage stock
V6 = slightly lower g.m. but a little more horsepower.
it all comes down to what means more to you!
hope that helps
Get the V6 5 speed, that's what i have and i wouldn't want it any other way. Decent gas mileage + some power (at least more than the i4). Its a super fun car to drive and looks real nice + its not all that common so when people see them they get interested in what it is. This is even more true if you have "T" badges.
Discussion Starter · #9 ·
What about the clutch and flywheel problems i hear everyone having. And is it true that even if i bought a new tiburon that this isnt covered by there warrenty.
Any problem with the clutch would be caused by a little spring in the slave cylinder, theres a DIY mod to take that out or you could take it to a mechanic. if you do that you will should have no problems with the clutch. even then if you didn't take out the spring mechanism, i would still say go for a tib!
Dedication to Thai Cuisine
The worst years for the clutch was the 03, 04 had some problems too, I believe. After that, the clutches are fine, unless raced or slipped like an idiot.
1 - 17 of 17 Posts
