1 - 20 of 181 Posts
I guess it's about damn time I made one of these. I've been involved with tibs since around 2004. Had an 03 silver that I modded a little. Then I got into an accident that totaled it. In 2007 I picked up the 05 that I currently have. It was my DD for a few years and then it became a little weekend car. Now the car currently has around 65k miles on it and I just got it back from the body shop.
Here's a list of what I had done at the shop:
-Full Repaint(Color: BMW Carbon Black 416)
-All Dents and Dings Removed
-Antenna Shaved
-Trunk Emblem and Keyhole Shaved
-Front Bumper, Hood, and Sideskirts Refitted and Rebraced
-Rear Pods Molded on the Rear Bumper
-eBay High Wing Replaced with OEM High Wing
-Deltas Painted
-Wheel Wells Painted
-Carbon Fiber Hood Painted
-New Tomato A&P Eyelines
-New F/L Headlights
-New Windshielf Wiper Cowl
-New Front Windshield(Old was chipped)
-Front and Rear Fenders Fully Rolled
-G-games logo on front bumper shaved
It all wasn't cheap either. This paint job is as perfect as I could get. All aftermarket body parts are solid, nothing was overlooked. I checked for runs, scratches, overspray, etc. Found nothing. That's what you should expect when you're paying close to $10k though.
New Work wheels have been ordered(Rotas are outdated). Going with a far more aggressive offset and width. I'll be installing the New Rear Wilwood BBK, New Weapon-R Engine Damper, New DC Sports Headers, New Front and Rear Hub Assemblies/Bearings, New ZMRMods Shaved Front Valve Cover, New MirrorFinishPolishing Polished Fuel Rails, New Engine Bay Plastics, and a couple New Interior Pieces that are just worn out over the next couple weeks. I'll also be ripping out the A/C soon and I'm having a custom trunk enclosure built by the same shop that did the exterior.
And here's how it sits currently:
I'll get some much better outdoor shots when the weather gets better.
MOD LIST
EXTERIOR
-Full Paint Job
-Full Body Kit
-G-Games Thunder Front Bumper
-GT Tech "Type 2" Sideskirts
-GT Tech Rear Pods(Molded)
-Zefiro Chaos Carbon Fiber Hood(Painted)
-Shaved Antenna
-Shaved Hatch Emblem and Keyhole
-KDM Chrome Door Handles
-OEM High Rise Spoiler
-Tomato A&P Eyelines
-Aerocatch Locking Hood Pins
-15% Window Tint
-Kickxtc 35 watt 6000k HID's
-Diode Dynamics 5SMD Bright White License Plate Bulbs
-FFF Painted Carbon Fiber Deltas
INTERIOR
-NRG Quick Release 2.0(Black)
-NRG Short Hub
-MOMO Millineum Sport Steering Wheel(Red Stitching & Piping)
-Polished/Chrome E-brake Cover
-System Upgrade Polished Vent Ring Set
-Full Interior Lighting Color Change(Orange to Blue)
-F/L2 Gauge Cluster
-F/L2 Center Fascia
-F/L2 Auto Shifter Indicator
-F/L2 Dimmer Switch
-F/L2 Metallic Window Switch Controls
-F/L2 Metallic Door Handles
-F/L2 Metallic Door Catches
-KDM Metallic Pedal Set
-KDM Tuscani Door Sills
-KDM Chrome Door Striker Set
-KDM Passenger Side Cup-holder
-Midnight Wolf Stainless Steel Tuscani E-Brake Plate
-Midnight Wolf Stainless Steel Tuscani Mission Plate
-Midnight Wolf Stainless Steel Tuscani Door Light Inserts
-Midnight Wolf Stainless Steel Tuscani Gauge Cluster Bezel
-Diode Dynamics 6SMD Board Bright White Dome Lights
-Diode Dynamics Bright White Glove Box Light
-Diode Dynamics Bright White Trunk Light
-Diode Dynamics Bright White Ashtray Light
-ATI Gauge Pod
-Two-Seater Conversion
ENGINE
-NGM Stage 2 Sniper Supercharger
-NGM 70mm Tri-Flo Big Bore Throttle Body
-NGM Stage 4 Lower Intake Manifold
-NGM Icebox
-NGM Solid Billet Motor Mounts
-NGM 360cc Injectors
-NGM Stage 2 ECU
-NGM 2.8" S/C Pulley
-ARK DT-S V2 Catback Exhaust
-DC Sports Headers
-Fujita Cold Air Intake
-ZMR Stage 2 EVAC Kit with Shaved Front Valve Cover
-ZMR Black SS Icebox Lines with Black AN Fittings
-MirrorFinshPolishing Polished Fuel Rails
-Weapon-R Engine Damper
-Mishimoto Polished Radiator
-Mishimoto Radiator Hoses
-Mishimoto Transmission Oil Cooler
-Greddy Radiator Cap
-Injen Oil Cap
-Midnight Wolf Stainless Steel Custom Valve Cover Insert
-Midnight Wolf Stainless Steel MAF Cover
-Billet "T" Dipstick Cover
-Glowshift WIdeband and Gauge
-Glowshift Boost Gauge
Suspension/Wheel/Brakes
-Ark ST-P Coilovers
-Ark Rear Sway Bar
-Ark Rear Strut Tower Bar
-RRM S/C Front Strut Tower Bar
-UltraRacing Lower Member Brace
-UltraRacing Room Bar
-NRG Harness Bar
-Moog Front/Rear Endlinks
-Ingalls Camber Bolts
-KJB Delrin Trailing Arm Bushings
-Ingalls Control Arms "Smart Arms"
-Nul7 Traction Bars
-Hyperblack Rota Grids(18 x 8.5 +44)
-Falken FK-452 235/40 Rear Tires
-Continental DWS 225/40 Front Tires
-Hyperblack GT3 Rota Center Caps
-Project Kics Revo R40 Lug Nuts
-Rays Valve Stems(Anodized Black)
-Wilwood Front Big Brake Kit
-Wilwood Rear Big Brake Kit
-Wilwood Stainless Steel Brake Lines
I.C.E.
-Pioneer AVH-P4200DVD Double Din Touchscreen
-Infinity Kappa 12" Subs
-Infinity Kappa 2-Way 6.5 Front Speakers
-Infinity Kappa 2-Way 6x9 Rear Speakers
-Infinity Kappa 4-Channel Amp
-Infinity Kappa Mono Channel Amp
-StreetWires Amp Power Wire
-StreetWires RC 4-Channel and 2-Channel Wire
-StreetWires 12 & 16 Gauge Speaker Wire
-Fatmat(Throughout Entire Car)
-Optima Red Top Battery
-Cobra Radar Detector
Obviously, as I mentioned before, there is still lots to be done. I've considered pulling the engine and moving up to a stage 3 or 4 or even going assassin, but I'm not sure if I want to get into that. I may pick up some new coils, as the arks need rebuilt. Also looking at some new Bride's. Just depends how much more I want to get into it.
Let me know what you think.
Discussion Starter · #2 ·
Had just enough of my zaino supply left to spent a solid 8 hours working on waxing/sealing last night. I can't wait to get this thing back on the ground with the new wheels and out in the sun.
Moonlighting Master
Re: Generalduke's Tiburon
It looks WAY better clean. I know it took them 11 years to finish the car but WOW was it worth it!!!
Discussion Starter · #9 ·
Thanks for comments guys!
Meh, only like half that long ;) Now I just need those new wheels :)
Moonlighting Master
Indeed! We'll finally be able to complete our tasks...I can't wait!!!
Premium Member
Looks sooo clean. I can't believe we've both been on this site this long and I've never seen a full shot of the car.
Discussion Starter · #12 ·
I can't either! :)
Thank you! I didn't feel it was worth showing before. Now I'm comfortable with it. Except for the engine bay. I have to start cutting up the new engine plastics this weekend so I can get them on there. Plus I'll get more detailed pics of the engine and the interior.
I like to see this black tib! It has got incredible interesting paint work.
It is looking really sharp the way it is, nice job!
Current rims are looking good on the car, but if you are working with Shadow on new rims.. You got me excited to see what is going to happen..
  • Like
Reactions: GeneralDuke
Lol holy **** are you kidding me?? This car is on another level. Well done sir.
Dedication to Thai Cuisine
And look at that kitchen you keep it in! I oughta eat right off that floor whilst masturbating the centerpiece~
ELITE EXECUTION ,TOP NOTCH ,AMAZINGLY WRENCHED TOGETHER ...
Just a few words that come to mind :3_nosthum.
1 - 20 of 181 Posts
