1 - 9 of 9 Posts
I need some infor on grounding kitts wich is the best i was gonna go with the
Hot Earth Earthing Wires inc Exhaust Earth and the
Hot Inazma - Type Hyper
but i cant find them anymore money is not a problem i just want something that you will see the best gains from and something that works the best
what do you guys think i should use now
also i seen apex-i has a grounding kitt is that any good ??
supposedly you can make them urself using amp wire and ring terminals. I know there was a DIY about it around here.
It really doesnt matter from which brand you buy them they are all the same. you can do it even yourself with amp cables and its the same^^^^^^
Switch-To-Start Battery Cables come in various lengths, look nice in black under the hood, and you can get em at the local car parts store - these are what I used - works great - here's an example of where you'd hook them up...
http://www.sokodo.net/~chad/2004_Hyundai_Tiburon_GT_V6/ground_wire_layout.jpg
But if you want to $pend more money, I'd get some of these...
http://www.sportcompactonly.com/performance-parts.aspx?c=78&pl=1478
EDIT: The top link shows the front wires grounded to the plastic radiator - DON'T wanna go there... :3_wink:
riggs1088 said:
If you are doing this yourself how much wire (how many feet) would you recommend?
12 - 14 feet should do it... and you'll probably have some left over depending on how you arrange things.
1 - 9 of 9 Posts
