Stock headlights?
Sounds like a bad ground, 1st to check is from the engine to the firewall, it's off the back of the upper intake manifold.
Also check battery connections.
If you can, put a voltmeter on the battery with the engine running and watch voltage while someone else operates the window switches. Voltage should stay in the mid 14 volt range. Check again but between the battery + and a good ground on the chassis.
A charged decent battery should be 12.6volts+, ~13.5volts engine running at idle & ~14.4volts at high idle.
