1 - 5 of 5 Posts
i'm just not too good in search in english so please enlight me the specs and the order of tightening.. thanks :)
Well to remove them is in this order:
3,5,10,8,2-top
1,7,9,6,4-bottom
To reinstall is this order
8,6,1,3,9,-top
10,4,2,5,7-bottom
Now there are M10 and M12 cylinder head bolts.
M10 is to be torqued at 18lbs.
M12 is at 22lbs.
Daniel
3,5,10,8,2-top
1,7,9,6,4-bottom
8,6,1,3,9,-top
10,4,2,5,7-bottom
M12 is at 22lbs.
Daniel
Don't forget the extra degrees of torque after you do the 22 and 18lbs. I think it's 65 degrees
but I can't remember. I'll have to look in the manual.
Discussion Starter #5
yes, thanks, guys, i found at webtech that it's 25 and nm +60deg+60deg...is it +120 , anyways we'll put the head on back again earlier than you'll answer:) thanks
1 - 5 of 5 Posts
