1 - 15 of 15 Posts
I just bought 4 18' rims from my friend at just 200 bucks with tires included, they dont fit well with sporty style, they are Tyfun brand, more like DUB and Baller stylez :ninjaman: however , for the price I didn't care much...
I just installed them today to find out that the Rear wheels rubs bad :(! :3_confuse they are at the very top of the rear fender..tires are 225/40 R18.. I dont know the offset of the wheels nor any other size, couldnt find em... Do you guys have any tips to avoid or at least minimize the rub? :3_confuse
its just on the rear part of the car...but its annoying cuz if I get someone with me, its rubbing all the time...
thanks
Roll those Quarter panels unless the wheels extrude beyond the outer edge of the body, then get some stiff coilovers.
Nick-Yes, I have boost!
The tire size sounds fine, so your issue is with your suspension if you're rubbing the top of the fender.
I would suggest to get coilovers, because if you're rubbing the top on a standard 18" size, you will rub on any. You need to stiffen your ride and potentially raise the rear.
roll the fender and some negative camber...i have dont it a bunch of times. the alignment rack is your friend.
even oem size with 25mm will rub ever so gently...so again alignment fixed everything.
^haha easton...i lived in stroudsburg for a couple of years...
offset would really help us out too.
Yea i'm sure you've seen the amount of rice in that area then. Florida > Easton any day!!!
he doesnt know!
and yeah...minus no good roads...i miss curvy roads. my suspenion mods are almost useless.
off/on ramps is all i have for the most part....although some in orlando are VERY nice.
roll the fender beeotch!!
1 - 15 of 15 Posts
