Hello I need a DIY to put on my adjustable coilovers . I don't know if the springs go first or I first have to put the aluminium screw. The problem doing that is that the aluminium tube hits a plastic cube in the midle of the piston so probably I need to remove it (is white) . My second step is to continue with the spring and after the aluminum cap ...
Im not sure! What I done now is first the rubber cup , after the spring , over it the aluminum cap and the aluminium screw (with the two exagonal locks) the upper part of the aluminium seems to go smoothly inside a sort of hole in the top stock
Damn!!!
some photo???????? need help!!!!!!!!!!!!!!!!!!!
Alex
Damn!!!
Alex
