Hi-Scan Pro for Windows Download (Dealer-Level Diagnostics)
Download Hi-Scan Pro with Car Scanner Device Emulator (CASCADE) v0.9.3 Windows PC emulation software (30.4MB Zip) - including the following ROM packs and misc. documentation.
Hi-Scan Pro User Manual included. This software is not DEMO, but instead FULLY FUNCTIONAL. No installation required - package (.exe) may be executed directly from a flash drive or saved to your local drive for permanent residence.
Clear ABS and SRS MIL's, program keyless-entry transmitters (see caution), initiate automatic transmission 'retrain' and many other dealer-level options including the ability to actuate modules and observe numerous sensor readings in real-time.
CASCADE Limitation:
Per user Airkix72:
This should allow for nearly full control and diagnostics of the ECU, BCM, SRS and ABS modules for a total investment of less than $60. You may of course build your own cable as opposed to using a breakout box, for working exclusively on Hyundai vehicles. To use the program with other makes & models may require undocumented mods, or none whatsoever.
Thanks in advance to everyone for their contributions.
Big hat-tip to airkix72 for the official Hi-Scan Pro user guide, his testing of various ODB2 cables, breakout-box pin-out and more.
ASIAN PACK1.bin
ASIAN PACK2.bin
EUROPEAN PACK1.bin
EUROPEAN PACK2.bin
HYUNDAI KIA.bin
KOREAN.bin
USA AUSTRALIA.bin
ASIAN PACK2.bin
EUROPEAN PACK1.bin
EUROPEAN PACK2.bin
HYUNDAI KIA.bin
KOREAN.bin
USA AUSTRALIA.bin
CASCADE Limitation:
"No automatic pin switching. The original [Hi-Scan Pro] diagnostic interface and corresponding cable is able to connect to ECU's with the K-line on pins other than 7 on the OBD connector. The low-price USB interfaces used with CASCADE do not have that capability, so it may be required to physically modify the OBD interface in order to be able to connect to such ECU's."
Please also see the following posts:
http://www.newtiburon.com/forums/showpost.php?p=4764649&postcount=41
http://www.newtiburon.com/forums/showpost.php?p=4765513&postcount=42
Per user Airkix72:
"Jump pins 8, 12, and 15 to pin 7 and you can access all the systems on hiscan..."
Here's to a new revolution in Tiburon DYI engine management.
