I also bought this cable too, but I still have to test it. I believe it is more editable
I don't have much issue viewing live data on my GK but I had to jump through a few hoops to get there. First I tried an Ubuntu host OS with Windows XP as a guest OS and it worked 50% of the time. I ditched Ubuntu and installed Windows 10 as my main OS and things seemed to improve.Did anyone succeeded with cascade and '98 RD (Europe)? As mentioned waaaaay before, it can communicate with certain modules. but as soon as you want to check DTCs or live (sensor) data in ECU menu, it crashes. I tried with two different ftdi based cables, in device manager 115.200 baud and 1ms, in cascade automatic, inceremental and manual baud rates. Using i5 4th gen, win 10 x64, fairly clean OS, 7, 8, 12, 15 tied together.
Windows is the only OS on my laptop. The strange thing is, one of my buddy experienced the same results with a 2.0 RD2. And in this thread some years earlier, there was a guy who tried with '98 RD, and another, who tried with lantra (same generation) with the same results. So I think it's a common issue, that perhaps solved by someone.I don't have much issue viewing live data on my GK but I had to jump through a few hoops to get there. First I tried an Ubuntu host OS with Windows XP as a guest OS and it worked 50% of the time. I ditched Ubuntu and installed Windows 10 as my main OS and things seemed to improve.
Modern PCs tend to cause issues communicating over the USB/Serial interface especially while USB3.0 is enabled. Try disabling your USB3.0 in the bios and turn on legacy USB mode. Also if you are running Windows as a guest OS instead of a host OS, you will have trouble. You may also need to enable compatibility mode for Windows XP or Windows 7.
