1 - 12 of 12 Posts
Oh man... so I just finished a 3 day battle with my steering wheel emblem.
First i tried the civilized way... just pulling with pliers. Then I went to cutting the **** out of it with wire cutters.
After failing at that, I took the car to the dealer to ask if they would do it. They wouldn't.
Then I tried to take off the whole front panel of the steering wheel, but one of the two torx bolts was freakin stripped so I can't undo it. mother****er.
SO finally I whipped out the driller, the pliers, the cutters, a screwdriver, and a pair of scissors.
well, the ****er is off now.
I cut a slit in the rubber of the steering wheel behind where the emblem sits to retrieve the two back bits that had been holding the H emblem on, and made sure that there weren't any holes in my airbag.
My god that was waaaay too much work for such a small mod. Plus the T emblem I got is crappy. Just a sticker. I have a different one on the way from dreamka4u.com, I hope its better...
Sheesh!
a sticker steering wheel emblem might actually be better. i wonder what a emblem would feel like hitting you in the head after your airbag goes off. i don't think it would feel to gooooodd....
Sam:Moderator of the Dead
chaos, it has been discussed before, the emblem will not hit you in the head because of the way the airbag breaks the steering wheel. The airbag will be hitting you in the head, not the steering wheel plastic.
Lighting and Accessories
Um... put it over the H. Problem solved.
I used a Dremel, it was too east 4 me! That sux u went thru all that trouble tho..
thanks for the info, i bet there is still a chance
and his new kimchi coupe
I used my big-*** SS hunting knife. Cut around the H so that the plate on the back stayed on, took me like 20 mins because I was being careful. Worked like a charm.
1 - 12 of 12 Posts
