Hello! It is my post in the forum, I am from Costa Rica and I see that many people know about the tuning of these cars.
I have a car that when it reaches high rpm with 7 psi of turbo starts to sound knocking detonations, I understand that it is because the ignition timing is very advanced (it is factory) and the problem is that this ECU does not have a Knock sensor that adjust the time so i have to correct it myself somehow
The car has FIC6 I know it's a bit obsolete ecu but it works, the problem is that like many people I can't delay the ignition time more than -2 because the OEM ecu seems to get scared
Another option that I thought of is to place a fixed resistance to the IAT sensor that simulates a very cold or very hot air temperature to see if I can correct it, but I do not know the optimal value of the resistance to achieve this.
The OEM ecu is not from tiburon, it is from accent 1.3L based on MAP.
Speaking of MAP it is not a problem because it is limited to 4.7 to avoid scaring the ECU under boost
With the above, can anyone give me some advice? Has anyone managed to delay time with FIC6 in these cars? any resistance value for IAT that you can advise me for this purpose?
Thanks in advance if you can help me
