Currently searching for parts for a i4 turbo setup. In this topic i will ask questions and post updates. (My car is 2002 i4 map non-cvvt LHD.)
I am looking towards 250-300hp.
Questions *updated 28-7-2022
1 What kind of spark plugs should i get? I heard about colder plugs but i'm not really sure what to get. i currently have Bosch FR8DII33X.
2 What clutch do i need and where do i find one?
3 What injectors should i get?
4 What turbo specifications should i look for?
5 Do i need an external MAP sensor?
6 is this wb af sensor kit good enough? https://www.amazon.com/Wideband-Sen...75&sprefix=Wideband+o2+sensor,aps,167&sr=8-12
Other parts i still need.
Fuel delivery system (5th injector or added fuel rail) ??? idk if i need this
Intercooler
Charge piping
Blow off valve
Boost/vac gauge
Oil feed hose and restrictor
Oil drain hose (tap oil pan or block)
Coolant feed kit (if required by turbo)
Any parts i forgot to list?
Parts i already got/know what to get.
Poly engine mounts.
Turbo Manifold.
Downpipe (i will get one made with a cat converter welded to it)
Tuning/remapping i found some tuners within 200 miles. as soon as @chase206 finds out how to read/write to my ecu this will be done.
If anyone can link me other parts that i need and will fit. *listed in this post ----> The definitive Boost your Beta Thread I would like to hear it.
Any suggestions tips and other information is also welcome.
Intercooler
Charge piping
Blow off valve
Boost/vac gauge
Poly engine mounts.
Turbo Manifold.
