1 - 12 of 12 Posts
so the more and more i read in this part of the forums i notice that no one seems to show much interest in the stealth kit. Any reasons i should know about??? it seems like a great kit, and i love the fact i can keep my stage IV intake and it will work with cams.
anybody have any ideas on this thing, tc? you created this monster whats your stand point behind it? are the sniper/assasin kits better/more power?
i know its more maint. but i am willing to do it as long as its worth it.
Mainly, because the stealth is alot more work.
BUT
I was wondering the same thing for a while, but I am still planning on getting a kit, and a built block, but not too soon. Gotta stack some cash for a while.. :(
cause people here (and only here) seem to like sc more? :2_rolleye
and mostly because you can be lazy with a sc too :)
Most of us like instant boost and low end power. Thats why we like the s/c better. At least that why I do. However I really love the turbo car sound... hehehe
i like turbos... but im not sure if im all about the work it takes.. i might just get a built long block, and slap on the assassin w/ mega air kit..
I had ordered a turbo but when T.C. put the Assassin out there I made a call and changed to the Assassin. I have run a few turbo Hondas with the same or close to the same whp I'll just tell you its not pretty for them.
chadoffl said:
I have the turbo kit and couldn't be happier. :)
oh i could be happier with the turbo kit, if i had a better clutcha nd could run more boost :)
thats my requirment for more boost happiness... LOL
just having finished the install of my stealth i would have to say it is because the thing is a ***** to install (but way worth it)....if you have a manual and a stock flywheel you pretty much have to pull the motor (although TC says it can be done with the motor in) in order tho take it off and get the oil return line welded in...that was the only real problem i had....so just have a slutch and flywheel put in before you install and the pan will drop right off....
or you could have TC do it as i think everyone else has.....except for like one other guy....in saudi arabia or something...
but the turbo does flow more than the assasin...and is cheaper....and only like 6 of the kits out their right now....so it is way more unique......and the stealth kit still holds the record for most power made on a delta
for now
hehe...you might top it...but when you do i will just have to get another credit card and put the assasin back under....lol
Discussion Starter · #12 ·
thanks guys for all the advice
so if i have a stock clutch and flywheel i am better pulling the motor and installing that and the turbo at the same time.
how long did it take you to do the install of the stealth kit??
1 - 12 of 12 Posts
