Not sure if specifically for tranny replacement, but there are some around for clutch replacement, which would give you most if not all of what you need since most people remove the tranny completely to replace the clutch anyway.
There is some debate on whether it's easier to remove part(s) of the subframe and do it from below or to pull the engine and tranny as a unit out the top. I've never done it myself so I can't comment on either method.
