1 - 19 of 19 Posts
i live in nc, southern states imports told me that to reprogram my keyless entry would be $193!!
the battery started getting weak in it so i replaced it. well i guess the hyun. keyfobs aren't like every other one in the world that gives you time to replace the batt.
doesn't $193 sound pretty steep??
-josh
btw 04 gt 6spd
lol,
can you say aftermarket alarm system?
i've heard that some dealerships in the US do it for free...
over here they wanted to charge me the hourly rate, which is about $40. That was already too much for me for a ****ing 5 minute job
Screw that. I would go around and find one to do it for free...at most like $20.00. You didnt get a second pad with your car?
You don't have to do any of that. Just put the key in the ignition, turn it to ACC and press lock and then unlock, and it will reprogram itself to the car. If it works, the parking lights should flash, and the locks should unlock and lock, if I remember correctly. I did the same stuff to mine when I changed my battery, and then I read through the manual, and that is what it said to do on my 03 Tib, try that first before you go and blow money! Someone should sticky the Key FOB reprogram, this is like the 10th time I have posted it, and I even made a thread about how to do it a long time ago! Oh well!
  • Like
Reactions: johnnyo
would that work with someone else's remote? as in, not your original remote....
Retired Staff | Track Rat
That does not work in Canadian Tiburons, or any other version that has an immobilizer.
damn candhams
go to a VERY BUSY DEALERSHIP... go to the service desk and say... u had work done there and now your remote doesn't work... they will do it for free!
Well he is not in Canada, and mine has the immobilizer and it worked. When my key FOB quit working, it would not let the car start. As soon as I did that trick, it made the FOB work again, and I was able to start the car, go figure! :3_nosthum
Did you get this fixed?
Thanks I was having the same problem. Now I just put it in and the lights flashed. Doesn't flash when I lock the doors but they are still locked. And I get the flash when I unlock em. Thanks.
i just dropped mine yesterday...and i brought my remote to have it reprogrammed, and the guy was like you'll have to pay, and i was like thats ******** for a 5 second job, so i told them to talk to the manager of Dean Team and he did it himself took 5 seconds for the reprogramming, that they were going to charge me $40
HEY this works!!!!!!!!!!! thanks
Glad to see this is still getting used! I am just curious why the Northern Tibs are not able to work! I know it is suppose to be because of the immoblizer, but my car has one and it does work. Is the Canadian version different? :3_confuse
Nope, doesn't work. This is on a US-spec 2004 GT.
Thanks for the info bud, got two key fobs both had dead batts.
1 - 19 of 19 Posts
