1 - 20 of 1480 Posts
Former Staff
If you are trying to figure out how a set or rims and tires will fit in your wheel wells, here are some simple examples to help you decide which rim width and offset will look best. I've printed this out and hung it by my computer and as I shop for rims on eBay I can quickly see if a set or rims will be too wide for my fender opening.
My calculations are for 18" rims only, because that's what I intend to put on my Tib, but the diameter shouldn't matter so these should be valid for all diameters. I highly recommend the following link found by Solo2Tib BEST RIM SIZE/OFFSET CALCULATOR to also help you decide.
STOCK RIMS: 17" x 7" Offset 46mm
STOCK TIRES: 215/45-17
STOCK DISTANCE FROM HUB TO WHEEL RIM LIP: 1.7"
STOCK DISTANCE FROM THE HUB TO FENDER LIP: 2.7"
The stock rim/tire setup leaves slightly less than a 1" gap between the rim lip and the inside of the fender lip. So, using some basic math, you will figure out that the distance from the hub to the inside of the fender lip (drawing a perfectly vertical line) is about 2.7". Taking into account that the width of the tire wall is about 0.5".
The rims you choose have to have a "DISTANCE FROM HUB TO WHEEL RIM LIP" value of 2.2" or less. Anything more and you might get some rubbing during hard cornering (unless you have a widebody kit).
Rolling your fender lips (or cutting them off) will give you an additional 0.5" of clearance, meaning the distance from the hub to inside of the fender lip (drawing a perfectly vertical line) will be 2.7" or less.
18" x 7.5" Offset 45mm
215/40-18 (Suggested Tire size)
DISTANCE FROM HUB TO WHEEL RIM LIP: 1.95"
18" x 7.5" Offset 42mm (Most common size for Tibs)
DISTANCE FROM HUB TO WHEEL RIM LIP: 2.05"
18" x 7.5" Offset 40mm
DISTANCE FROM HUB TO WHEEL RIM LIP: 2.15"
18" x 7.5" Offset 30mm
DISTANCE FROM HUB TO WHEEL RIM LIP: 2.35" Possible Rub
18" x 8" Offset 45mm
DISTANCE FROM HUB TO WHEEL RIM LIP: 2.2"
18" x 8" Offset 40mm
DISTANCE FROM HUB TO WHEEL RIM LIP: 2.4" Possible Rub
18" x 8" Offset 35mm
DISTANCE FROM HUB TO WHEEL RIM LIP: 2.6" Rub, unless rolled fender
18" x 8.5" Offset 35mm
225/40-18 (Suggested Tire size)
DISTANCE FROM HUB TO WHEEL RIM LIP: 2.85" Rub, unless rolled fender
18" x 8.5" Offset 30mm
DISTANCE FROM HUB TO WHEEL RIM LIP: 3.05" RUB
18" x 9" Offset 35mm
??? (Suggested Tire size)
DISTANCE FROM HUB TO WHEEL RIM LIP: 3.1" RUB
18" x 9" Offset 30mm
DISTANCE FROM HUB TO WHEEL RIM LIP: 3.3" RUB
Hope this helps!
Also see Post #2 for the info created by STAW512
The NEW "Does it fit" thread
Here is a bunch of information on the tiburons lug pattern, and what size rims, tires and drops will work.
The Tiburon's bolt pattern is 5-114.3
Stock Rims: 17" x 7" Offset 46mm
Stock Tires: 215/45-17
Stock distance from hub to whell rim lip: 1.7"
Stock distance from hub to fender lip: 2.7"
Wheel . . . Offset . . .Tire . . . Notes
Stock Height
17x7.0 +35 215/45/17 , 225/45/17 , 245/45/17(slight rub in F)
17x7.5 +38 225/45/17
17x7.5 +40 235/45/17 , 225/45/17
17x8.0 +42 245/40/17
17x9.0 +45 255/40/17(R only w/ 5mm spacer and rolled fender, still slight rub)
18x7.5 +38 225/40/18
18x7.5 +40 235/40/18
18x7.5 +45 225/40/18
18x8.0 +35 225/40/18
18x8.0 +46 225/40/18
18x8.5 +35 225/40/18
19x8.0 +40 245/35/19
19x10. +25 275/40/19(R only, w/ widebody and fender roll, slight rub)
19x9.0 +50 245/35/19(w/ widebody, slight rub F)
Pro-Kit (or equivilent)
18x8.0 +40 225/40/18 , 235/40/18(slight rub)
18x8.0 +45 245/35/18(rolled R fender, slight rub R)
Sportline (or equivilent)
17x7.0 +38 235/40/17
17x7.5 +40 225/45/17
18x8.0 +?? 235/40/18(bad rub and fitment)
Tein S-tech (or equivilent)
17x7.0 +45 225/45/17
Tein Coilovers (or equivilent)
18x8.0 +35 225/40/18(set hard or will rub slightly)
Espelier (or equivilent)
18x7.5 +30 235/40/18(slight rub F)
Tanabe DF210(or equivilent)
19x7.5 +45 235/35/19
B & G (or equivilent)
18x7.5 +40 225/45/18
Dropzone (or equivilent)
18x7.5 +40-45 225/40/18(slight rub, on bumps only)
Re: The NEW "Does it fit" thread
Just to make sure I am readling this correctly, for example:
17x7.0 +35 225/45/17 will fit with no rubbing. Correct? What about on a lowered car?
come on dude... i dont know, i just reposted the info because the orignal poster took it down
photo... I am not sure about the offset but I ran a 235(top of tire) / 45(sidewall) / Z(speed rating) R(means 1 spin direction) 17(diameter of rim) on the stock height and didnt have a problem...the 45 stands for 45% of "225" so... I think it = 101.25mm where mine was 105.75... you should have 4.5 millimeters is equal to 0.1771653555 inches... almost no difference
photo... I am not sure about the offset but I ran a 235(top of tire) / 45(sidewall) / Z(speed rating) R(means 1 spin rotation) 17(diameter of rim) on the stock height and didnt have a problem...the 45 stands for 45% of "225" so... I think it = 101.25mm where mine was 105.75... you should have 4.5 millimeters is equal to 0.1771653555 inches... almost no difference
I was worried about the offset, I currently run 225's.
Thanks
If Tein S tech can run with 18x8.0 +35 225/40/18
then the prokit should be able to do it as well right?
Stock Height
I just bought IKON GT5 19x8.5 rims with 225/35/19's. My car is the stock hieght not droped.
Just wondering if anyone knows if I will rub at all or if I need to buy spacers for the hubs?
Thanks for the info.
whats your offset?
19x8.5 5x114.3 +20/38 225/35R19
That is the specs for my rims, and the offset.
does anyone know if 235/55/17 with 17X8 inch rims will fit on a stock 03???
I think it'll rub b/c tall side wall
plus your speedo is gonna be wayyyy off
get like 235-45-17 or 235-40-17
So I was looking at a pair of 17x7, 46 offset rims with 215/40/17 tires.
I wanted to check to make sure the set would look good.
that wheel is same size as stock wheel
if you go with shorter sidewall your speedo will be off.....and you'll have bigger gap in between tire and fender
i had on recently 225/45/18 slightly stretched on a 18x8 with +35 offset.. prokit drop... slight rub...... 225/40/18 probably wouldnt rub at all or very little if any....
on +46 17x7 wheels , 225/50/r17 fit with little to no rub. tested by me.
18x8 +35 offset with 225/40/18 tires on stock suspension
fits perfectly, no rub at all.
fyi though, i think it also depends on the style design of the wheel. well that's what someone told me. i could be wrong.
