1 - 1 of 1 Posts
2006 tib 2.7..ive changed this engine several times..I'd just got all the sensor tweeks to have the engine running well..I had to make a dude stop at Walmart...it died..but did fire and try to start..for a minute..then no fire..put crank sensor I know worked..no fire..I checked all the grounds.then discovered the crank sensor as well as all the rest was only getting about 4 volts where it should have been twelve..this had happened before and I jumped a 12 to the crank sensor and it worked..this time it didn't..the sensor and injector fused only had about 4 volts in the fuse box..after jumping 12 to those fused there was still only 4 or so down the line at the sensors..how is that even possible..I've inspected the wires as far as I can get to no short no break..can anyone please help
1 - 1 of 1 Posts
