Following the performance
regulations for the 2WD Open rally class I'll be entering my 2004 Tiburon GT into; for an engine to be turbocharged it must be 2.5L or less.
With the Tiburons V6 engine putting out maybe 200whp (ideal max) with all possible NA mods other than a built block and NOS injection, it will make it difficult to compete with the other NA and turbo vehicles (Which are normally running 225-350hp depending on their weight and restrictions)
With the Tibruon's V6 having a displacement of 2.7L, this means I either have to rebuild the whole engine for NA performance ($$$) or instead reduce the displacement of the engine so it's eligible for use with a turbo (hopefully possible and not as expensive as a full NA build).
To reduce the engines displacement I either have to reduce the cylinder bore and/or reduce the engines stroke. As far as I know, this can be done through the use of cylinder sleeves and custom pistons, or with a crankshaft custom grinded to the right stroke and custom pistons.
The only other option I can think of is using NOS for extra hp, but this doesn't seem too practical for rally racing and I'm not sure if it is even allowed under the regulations/restrictions.
Does anyone know what the easiest and most cost effective route would be? Has a displacement reduction ever been done on a Tiburon V6 before? I'm starting to think I'm mostly SOL with hoping to reduce the displacement without spending $$$, but I figured I'd try asking the forums first.
Any help is greatly appreciated.
Thanks,
Z
Thanks,
Z
