1 - 6 of 6 Posts
i have a 4 cyl tib and am wondering if there would be any gains witha mafterburner on a tib with i/h/e and a few other goodies.
does anyone have any 4 cyl tuning tips
with tuning you will always have gains, however I'm not sure if there is a correct wiring diagram for the mafterburner on an i4. Also you need t know if your a maf based car or map based. If its map based then a mafterburner will not even work
maf car its an 08. im just lookin into getting a better tune i hear that the stock computer floods the enngine at high rpm.
The MAFTerburner should work find provided you can get the pinouts for the unit. Chances are it has a RPM tap, MAF in and out, and power and ground. Fairly simple to wire up in the engine bay. As long as you can get it reading the correct RPM then you should be good to go!
I would like to learn how to use one of these as well with my '08.
dmdicks dont u know how to use smt6s and what not is there a tune for an na set up?
1 - 6 of 6 Posts
