1 - 5 of 5 Posts
By mistake alternator wires the black one touch with the exhaust burn a bit now battery light is flashing i want to know if the problem can fix or need to replace alternator
Best bet, meter all the fuses under the hood and under the drivers side dash in the BCM. Likely cleared a fuse and the alternator is no longer charging. Looking at fuses is not the best, meter them.
Yeah you probably popped a fuse when you shorted the wire. This is why you ALWAYS disconnect the battery whenever you mess with anything electrical--especially the alternator.
1 - 5 of 5 Posts
