Timing belt broke..redone heads..2.7l.06 tiburon..it started right up ..rear cam got off three teeth ..bent valves..redone heads..it started..then it wouldn't start..was told and convinced it was my work on the heads ..motor was shot...didnt think it could be..bought another 2.7l out of kia optima..it ran ..put it in the tiburon...now it wont start...getting fuel..dont seem to be firing...same as other motor..help..what would make it not fire
timing tensionser is one. second, coil packs, spark plug wires, and spark plugs.
Be sure the wires are connected, and not brittle and cracked, that go too the coils. How do you know there is no spark? won't spark timing light? Get your little brother or equivalent to stick a plug wire on a finger, then you crank it over. Thats the most certain way to identify spark / no-spark conditions.
