I am in the process of putting my Alpine sc back together (I had to replace one of the snout bearings that sits behind the pulley because it cracked). I know the sc itself needs oil obviously but I'm referring to the space above that in the snout with the rod and bearings. Does that space need oil as well or do the bearings just need to be greased?
Discussion Starter #2
I am adding a picture for reference. I know the red area gets sc oil. But does the blue area need oil as well?
Discussion Starter #4
After more research I think that is correct, most forums I find talk about refilling the snout oil and greasing the needle bearings but not the bearings in the snout. So it must be lubricated by the sc oil itself.
