so i installed it finally, the question is in tuning i think . i already angry at myself that didn't buy a reflash from kdmguy or someone.
i did connect the tps ,the map and the wideband's coverted to narrow signal.
i made the changes that i think are appropriate..
it idles rather fine. when i push the gas like a feather, it raises it's rpm. it returns to idle without problems, but when i push the gas more, it loses or how to say, it pauses on lower rpm for sec-two and left at that moment can even die. if i try to move on the first gear as i did always without pushing the gas, feathering the clutch, it tries to die, when i give more gas it tries to die when i start to let go the clutch. my wideband is jumping everywhere, nowhere stable , i think i messed with a bad ground or something.
what would you advice to try next?
