1 - 3 of 3 Posts
I have a 06 2.7 v6 tonight was out driving had been all day I have the car in neutral and the RPM started going up tried giving it some gas in the car died took a minute to restart then car ran fine twenty minutes later RPMs went back up in neutral but didn't die this time get it home pop the hood radiator hoses are extremely hot but radiator cap is called take the cap off and white foam power steering hose near idle air control covering melted squeeze the radiator hoses with the cap off and no fluid whatsoever no coolant in the oil nothing in the overflow cars running fine no white smoke out of the exhaust does anyone have any ideas of what it could be
How often do you check and top off fluids? Should be every few weeks or every other has fill.
I would check and fill your fluids, then run it again.
I've had the car a few months now and been good about checking fluids expect radiator I've never checked it till last night
1 - 3 of 3 Posts
