1 - 2 of 2 Posts
When I bought this car, the headliner would start to feel wet after it rains. I did research and found out it could be the drain tubes from the sunroof. So I took apart the interior trying to see if I could fix this problem, but when I got to the sunroof there were no drain tubes. Is this a common problem or is my car sunroof aftermarket and they just didn't put in drain tubes? If someone can help me with this, it would be appreciated.
If it's OEM there should definitely be drain tubes. They go from each corner down to the wheel well areas (rear ones for example run behind the rear speakers). People often complain of the rear speakers crackling if the tubes get blocked or disconnected back there.
1 - 2 of 2 Posts
