Oh ok, I see now it's just the clutch disk splines poking out. You are right this doesn't look right at all. For reference check out the video at about 19min to see the depth of their clutch in the center of the pressure plate.Actually the tob is not installed. I have it on the spline to get snapped in to place once I figure this out.
Care to share the link to the kit you bought? Often times Amazon and eBay sellers try to pawn off subpar components as a "Valeo" kit but actually only the disc or the pressure plate are Valeo brand. If you spent less than $400 on that kit it's likely missing quality components that you need like the TOB which is a common failure point.It was a valeo clutch max kit off of ebay. I sent them a message with all the part #s to make sure they had not made an error. Probably won't answer till Monday though. But it does seem they may have sent the wrong disc. The pp and fw match up perfectly. The disc lines up and fits good but just don't seem to sit correctly. Thanks for all your input. I am grateful.
