NGM Next Generation Motorsports 70MM BBTB Big Bore Intake Throttle Body 2.7L V6
This very rare throttle body was stripped, polished, and reassembled- before running a short previous installation. The butterfly rotates smooth and closes firmly. Perfect for all turbo/boosted applications or an inclusive N/A build. Personally made my RPM idle a little higher but worked pretty good in terms of performance and quick return. Sold AS-IS.
This beautiful custom throttle body is designed to get the maximum much needed airflow into your engine without sacrificing motor reliability. The big bore will show you a significant increase in throttle response. NGM stopped making these nearly 10 years ago. You can NOT buy this anywhere! Fits all 03/08 2.7L V6 Hyundai Tiburon engines for a streamline bolt on plug and play application, with very little to no major adjustments required.
Mounting hardware, sensors, sensor equipment, and gasket not included. Note: You must cut out a larger gasket for installation.
Asking $590 plus shipping + 3% PayPal fees...
Please Contact John @ 954-937-5744
Thank You.
🌟 Hyundai Tiburon 03-08 NGM 70MM BBTB Big Bore Turbo Intake Throttle Body 2.7L | eBay
www.ebay.com
Thank You.
