The lock on the key fob also does not work. This problem began happening sporadicaly and would either work fine, not work at all or go bonkers and keep the lights on after the engines off and randomly start blinking turn signals.
The relay on the BCM gets tripped and starts clicking doesn't stop til it decides to or i yank the negative terminal on the battery. I changed this relay up the DIY method on this site to fix the stuck turn signal when i bought the car.
Sometimes I could activate the power windows by locking and unlocking the fob while driving although this would usually trip the relay.
Has anyone had this problem yet and found a solution, thanks
