Hyundai Coupe 2.0 2007
Hi crew!
Today I noticed something different when I tried to open my driver side doors (both from inside and outside, multiple times):
  • I had to pull harder
  • there is a "notch" felt durring the handle pulling (both, exterior or interior one the same feeling)
Additional info:
  • nothing should be frozen
  • its not cold outside
  • lock/unlock works fine
  • remote works fine etc.
Did search but did not stumble upon exact issue. Mostly door lock actuator problems poping up...
Thanks for any help!
Discussion Starter #2
Got a resolution for my own thread... If somebody searches for simillar problem:
The problem is door Latch (that little black plate inside door that rotates upon pulling the handle) and door "Striker" (that hook on the car that latch latches to).
There is adjustment procedure in Body Service Manual for the striker plate:
It is a TORX screws so bare that in mind.
I have adjusted mile little downwards and towards out of a car AND used a little "Lithim greese" and now it is much much better.
Hope it helps somebody!
I would still lube things....sounds like lube is gone and making it harder to work.
PS, thought I had replied earlier to this regarding lube....
  • Like
Reactions: Mladen
