1 - 8 of 8 Posts
Went to start my Tiburon and when I turned the key nothing happened. Instrument panel didn't light up, engine didn't turn over. When I turned the headlights on the instrument panel lit up so I figured that the ignition switch was the problem so I replaced it and nothing changed. Any ideas?
I wouldn't have started with the ignition switch but...... good you ruled that out.
Have you checked the fuses? Have you tried jump starting it?
Had the same issue it ended up being the starter plus I had some bad wiring that was burnt so I fixed the wiring but I still had fuses blowing ended up changing the starter and it fixed the issue
1 - 8 of 8 Posts
