1 - 9 of 9 Posts
Anyone have a pinout for the OBD 2 connector under the dash? HMA Service seems to be down for me, crapped out and won't come back. Thanks.
If your looking for the location of the pinout, it's on the left hand side of the sterring wheel, down a little bit in that fuse cover. Pull the cover and you can't miss it.
I am actually looing for the pinout chart, as in what each of the wires on the connector go to. IE..rpm signal, voltage. I think 14 of the 16 pins have wires.
Like:
1-
2Bus positive Line of SAE-J1850
3-
4Chassis ground
5Signal ground
6CAN high (ISO 15765-4 and SAE-J2234)
7K line of ISO 9141-2 and ISO 14230-4
-8
-9
10Bus negative Line of SAE-J1850
11-
12-
13-
14CAN low (ISO 15765-4 and SAE-J2234)
15L line of ISO 9141-2 and ISO 14230-4
16Battery voltage
Sam:Moderator of the Dead
This is off an 04. I doubt they changed it any.
1-ABS
2-K-Line
3-Blank
4-Sensor Ground(speed sensor ground I believe)
5-Ground
6,7,8-Blank
9-Memory power
10-DCT
11-Speed Sensor
12-Blank
13-Air Bag
14,15,16-Blank
Ok, I was wrong. They did change it. Here is for the 05.
1-ABS/ESP
2-K-Line
3-CAN-HIGH
4-Sensor ground
5-Ground
6-Speed Sensor
7,8-Blank
9-Memory Power
10-DCT
11-CAN-LOW
12-Blank
13-Air Bag
14,15,16-Blank
Rool : Pron Spammer
Actually, the Hyundai numbering in the manual(s) is backwards. OBDII standard has pin 16 as battery voltage, pin 6 is CAN_H, pin 14 is CAN_L, etc. I figured this out when I was making an OBDII cable for the scanner I built.
1 - 9 of 9 Posts
