1 - 12 of 12 Posts
How big is it? and has anyone tried putting another sub the same size n it? I dont think there are amps with the sub because i notcied the box is ported.
there is an amp behind your drivers seat between the seat belt and the speaker... kinda
Yes the stock sub is an 8" as far as mounting a different sub you have to cut out the plastic tube in the back that holds the rear mounting bolt for the sub then find a sub with a shallow mounting depth that only requires about 0.7 cubic feet of airspace. I will be attempting to mount a 10W6V2 in a week or so when I finish getting all the components I need together, I will let you know if it works.
just look under the diy section. all you have to do i rewire the harness conecting the sub and it bangs well at least mine does.... takes like 15 minutes
TiburonTemptress said:
About this OEM sub. Within the next 2 weeks I plan to install my box, deck and all, but until then whats the deal with this OEM sub? Mine barely pumps....like I wouldn't even know it was there. Where can I adjust it???
yea bro i looked under the DIY section n its mad easy to switch the R n L wires on the Sub connector...most time was spent taking the 4 bolts out so u can remove the sub....imy sub PUMPS now....like i barely turn it up n i could hear it comin down the road....i used to have a kenwood dual 10" bandpass box and kenwood 600W Amp powering it in my old car but after i got this car the other day!! :3_smile: n flipped the Rn L wires, it sounds good enough that i might not even put those in n sell them so i can save money n keep weight down..
seriously when i got this car the other day n heard the sound system n then saw that sub in trunk, with how big the trunk is n it being empty, i could NOT believe it barely put out any bass....but after switching those wires, it works like its supposed to n puts out alot of bass.....anyone know of other simple DIY fixes not on the DIY page that are as easy as the sub wire switching??
Just keep in mind that the sub problem is supposedly fixed on newer Tibs...
Now mine, being old, I did the stock sub fix and it worked great.
Also, just another fun fact on the stocker, it's a dual voice coil sub.
I have an 04 and did the sub DIY and it is better, but you guys talkin like the thing hits like a box are smoking crack. It hits harder than original, but nothing amazing. :3_saai:
They did fix the problem on the new tibs mines an 06 and the diy made it sound worse.
well i guess i wont do the DIY on my new 06 when i get it tonight
1 - 12 of 12 Posts
