1 - 3 of 3 Posts
My sunglass holder broke and didn't open as it should. So I took it down (lens first and start with the side facing you, than 4 screws).
Hood Wood Gadget Automotive exterior Automotive design
Remove the spring from the square hole (don't worry it is fixed and won't fly away).
Bag Vehicle Luggage and bags Beige Personal luxury car
Drill a 2,5 mm hole (because the original shift and hole is 2,5 mm). You can see the spring and its fixing points.
Font Household hardware Metal Auto part Art
I inserted a nail and I used bottle stopper (I cut a small piece that goes on the side). I also made a small hook from paper pin to fix the spring back.
On tape you can see a small piece that broke away. After fixing I replaced old bulbs with LED. I used some Osram and they light up faster and even that they are not dimmable they also dimm a little.
1 - 3 of 3 Posts
