1 - 5 of 5 Posts
How hard is it to change out pads and rotors? I may buy some wheel spacers with extended lugs, so if I get them I will do pads and rotors at the same time. If I understand this correctly in order to put in the longer wheel studs you need to remove the rotors to get to them.
yeha it is not that hard to do but you will need spacers for tht wide body
it isn't hard, but I would have someone with me that knew what they were doing the first time, you don't want to get stuck without brakes and have no way of driving
1 - 5 of 5 Posts
