1 - 3 of 3 Posts
At AutoZone they have a kit that comes with brake cleaner a brush and paint. Use that.
negative, tried that and it cracks and peels with one small rock chip, however they sell and actual airisol can for brake calipers VHT is the brand, i picked mine up at autozone or advanced auto, but anyways honestly the best way of doing it is to remove all 4 calipers from car, yes pinch off the brake lines or w/e, i just let mine bleed out and ran new brake fluid, but lay all 8 pieces out, spray and clean with engine degreeser or caliper cleaner and using a wire brush to get them all nice and clean, apply 1 thick coat of primer (i used high temp engine primer) spraying it with light sprays evenly till its covered kinda thick. Let it dry for about 15 mins then do a light coat of paint (note: you should keep it light enough to still see primer) then wait approx 5 mins, apply another coat to cover all of primer, wait 15 mins, another good coat, wait 15 mins, now i did 1 more coat making it 3 coats of paint but its up to you, then do a light coat of laquer clear coat, then a slighter heavier coat then Walla!!! Now the sucky part, wait a good 1 to 2 hrs before installing back on car, you dont want to leave your finger prints in the paint lol.
I did mine blue, with custom flat black rotors and wheels, if anyone wants to see a pic, let me know, the brakes look like they came from the factory that way, Faus03 can vouch, he helped me! :)
1 - 3 of 3 Posts
