i have an 03 gt. i started my car this morning the clock was at 1 am. and their is no power to the radio. i cant change the time on the clock and it resets it self after about 10 to 15 min of driving. also when the key is on acc, when i hit the window buttons the clock resets it self. the radio is an aftermarket cd/dvd, but it has been working for the laast 3 months. when i start the car the speedo needle jumps to 120 for a few seconds then falls to 0. the tach will jump around for a few sec then fall to idle. the other two guages do the same thing. the only thing that i have changes is the battery, a few days ago. the car starts fine, and ive disconnected the batery and reconnected it. still the peoblem is there.
thanks for any help
If you go into your fuse box inside the car, look to the left and you will see a big yellow fuse. That is probably blown.
^^^ yea, i had the same exact problem, my fuse was blown and nothing electrical worked in my car. take the yellow one out and put a new fuse inside and you'll be set.
Thanks alot guys, problem solved
