i installed 6x9 rockford fosgates in my 04 tibby and they sound great but im having a hell of a time with my 6 1/2 compnent system. the speakers are too deep so i needed speaker spacers but the ones made dont fit the tibby. the bracket is too small what do i do and has anyone replaced the tweeters in the top of the doors....let me know how to get the clearance and can i get different grills instead of them damn infinity ones...all of this is being run off of a 450.4 rockfrod 4 channel...sounds good with just the rears and will sound sick with the fronts just gotta figure out what to do......leave any comment please
You can make your own brackets from pressboard. just use some gasket sealer between layers. As far as the tweeters go, I just ripped the factory ones out and put mine inside. Just push it up against the grill, then put a piece of a plastic bag over the back of the tweeter and spray some expansion foam over it (very small amount). Once it dries to the shape, take a sanding block or a knife and smooth off the back of it so it will fit flush against the door.
I used a piece of 1/2" MDF to make my speaker ring spacers for my Type-R's. Just make sure you cut them to the right design and you also have to trim the plastic ring on the door panel to make it fit back on flush.
