1 - 3 of 3 Posts
Does anyone know if their flywheel is designed to be used with Clutchmaster clutches only?
I'm pretty sure you can use a CM flywheel with any clutch as long as the clutch is un-sprung because the CM flywheels are not compatible with sprung clutches of any kind.
Actually, it appears that I no longer have any idea what I'm talking about (spung/un-sprung); but there is no reason why the CM flywheel wouldn't work with another clutch.
Thanks for the info..
1 - 3 of 3 Posts
