I'm about to order my new 17" rims to go with my new set of tires. I was reading and noticed that the stock offset was 46mm and my new rims are going to be 42mm. Should I run into any problems? Here will be my setup
Megan racing lowering springs
17" rim/7.5 with/42mm offset
215/45/17 tire
Also, the bolt pattern they have listed is 5-100, that's the correct bolt pattern right?
Thank you
um no rim expert, but the offset sounds fine. butt the tiburon lug pattern is 5X114.3 i think?...
Retired Staff
5X100 will NOT fit the Tiburon
You need 5X114.3 !!!!!
