noits onlyin nuetralslow 2K2GT said:I had the same thing with my install on my 02 XD when I had it, was a low knock knock knock, more audible when in gear then in neutral. Dont know what happened either, I would be interested to know though. You installed the Cluthmasters Stg 3 right?
Were you drunk when you wrote that...I dont know what to tell you then, not even the same as me. Good luckphlash said:noits onlyin nuetral
BlackTibGt said:the thing with clutches, you cant touch the friction material at all. if anytihng gets on the material it will slip on your flywheel and cause hot spots...this is whats causing your rattle...trust me on this one i just graduated from automotive technology and my last class was manual trannys and clutches...
exactly,,,,same here. Perhaps he's got the parts mixed up ? Cause hot spots didn't cause my stocker to rattle,,,but it was severly burned,,,,personally I think it's the lightened flywheel making the noise like timgeorgi said.yeah, and my factory never rattled and it was toasted and full of hot spots so what gives?
