1 - 6 of 6 Posts
Just follow the wire. It goes up inside the rear hatch, near the rear strut
Thanks for that did pull the door trim open and could not find it . Have not taken the back seat out yet to have a look below as wife is still using the car Thankyou for your replie.
Pull the back seat belt cover off and look down inside. You may have to pull back some of the trunk trim but as I recall you don't need to remove the side trim panel or the back seat.
Ok will have a chance to look over the weekend. Found a manual on line and that one tells you to look under the panel in the rear trunk . So got to options now thanks for your reply.👍
1 - 6 of 6 Posts
