I took off all 6 screws and it seems like its still stuck? how do you get it off?
NO JOKE! god that thing was so annoying!peachferrari said:Just so you guys know if it's an '05+ the glove box isn't that easy to get out. There is a wiring harness connected to the back right hand side. It's a big thick harness connected with a plastic bracket and metal ring. When I took my glove box out I managed to weaken the bracket some with a screwdriver, but I ended up just yanking the crap out of it and broke the plastic bracket. It's a real pain.
Are you taking it off in order to paint it? I was going to make a thread tonight about it, or at least search around. I don't remember if I had it out before, but I did install the cup holder. Did you get the pieces painted by a shop, or did you DIY? All mine are painted, except a few, reason for wanting to take the glove box out. And it did take me couple hours to install the cup holder, I had an impossible time getting at a few screws! ; )korean_evan said:I took off all 6 screws and it seems like its still stuck? how do you get it off?
Yours is a 2003 I take it? Maybe they have changed the fasteners in between. I have tried unsuccessfully to remove the glove box from my 2006 several times now. Pulling it down/forward/sideways/tapping/yanking/etc to no avail...after you've removed the screws, open the glovebox, and the give the open part a good tap in the middle, the rest of the glovebox should pop right out. easy as cake
See my post above. I'm sure you have the big fat wiring harness connected to the lower right (passenger) side. It's a pain in the rear until you get it out the first time.Cross_ said:Yours is a 2003 I take it? Maybe they have changed the fasteners in between. I have tried unsuccessfully to remove the glove box from my 2006 several times now. Pulling it down/forward/sideways/tapping/yanking/etc to no avail...
