1 - 20 of 824 Posts
Exterior
HEXIS Lapis Blue Variochrome
Aerocatch Hood Pins
2.7 Elisa Badge
Shark Racing V3 Angel Eyes
NIA Front Splitter
NIA Side Skirts
NIA Eyelids
Custom Vented Hood
Custom Gills
Shaved Emblems
Shaved Antennae
Shaved Trunk Keyhole
Shaved Front License Plate Mount
Interior/Audio
Nissan Maxima 6 Speed Shift Knob
e3io Custom CarPC
Clarion Amp (400w)
MTX Jackhammer 12" (400w)
Custom Leather Sub Enclosure
Custom Leather 2 Seater Conversion
GTMAT 50mil Soundproofed 100ft²
KDM Passenger Side Cup Holder
Engine
NGM Sniper Supercharger
NGM 70mm Plenum
NGM 70mm BBTB
CP Forged Pistons 9:1
NGM 7" Lower Crank Pulley
Billet 2.8" Supercharger Pulley
Fiebruz Stage 4 Reflash
Apexi NEO
Bosch 190lph Fuel Pump
Snow Performance Stage 2 Methanol Injection
Custom Twin Stage Intercooler ~ Derale 15865, Custom Tank, SS Lines, Russell Fittings
Odyssey PC680 Lightweight Battery
ARK Lightweight Power Steering Pulley
Billet Lightweight Alternator Pulley
Billet 2.8inch Supercharger Pulley
Mishimoto Radiator
Mishimoto Slim Radiator Fans
Shaved Valve Covers ~ Custom PVC -AN6 Setup
Shaved Fuel Rails
Mishimoto Billet Oil Cap
Acrylic Conceptions Custom 1 Piece SS Valve Cover Insert
Acrylic Conceptions SS Fuse Box Covers
NGK Spark Plug Wires
NGK Iridium 7 Heat Range Spark Plugs
Zeitronix Zt-2 Wideband LCD
Zeitronix Boost Sensor
Zeitronix EGT Sensor
ADD W1 Anodized Magnetic Oil Drain Plug
ADD W1 Anodized Baffled Catch Cans
Edlebrock SS Fuel Lines
Edlebrock SS PCV Lines
Edlebrock SS Icebox Lines
AEM CAI
Ark Headers
Ark 3" Single Exhaust
OBX Radiator Hoses
Suspension/Brakes/Transmission​
JNC 005 18x9 +30 Wrapped in BFG G-Force 255 35r18
HSD Monotube Coilovers
RRM Front S/C Strut Bar
RRM Rear Strut Bar
Phantom Grip LSD
R1 Premium Drilled/Slotted Rotors
Stoptech Brake Pads
Stoptech Stainless Steel Brake Lines
TWM Shifter Cable Bushings
TWM Shifter Base Bushings
KJB Billet Front Mount
KJB Billet Rear Mount
HEL 350z SS Clutch Line
Spec Stage 5 Clutch
Fidanza Lightweight Flywheel
Slave Cylinder Mod
Custom Traction Bars
Moog Endlinks​
Req's Boost Build
Videos - 2013
Stage 2 2nd Gear Pull - With a passenger, full sub + interior
Stage 2 1st-4th (10-105mph ish) - With a passenger, full sub + interior; est 3400lbs or more
Both pulls were @ 250whp ish. I could be running more but that is what i think i was at if i were to put it on a Dyno.
Videos - 2014
30km Into The Built Block
Hydra 2.7 N/A
Assassin - Start Up - Hydra
Assassin Rev
Awards
Newtiburon.com Best Overall Member Of 2013
Newtiburon.com Most Likely To Be Named A Staff Member For 2014​
Discussion Starter #6
Re: Req's Rally Red
Really clean and nice ride!
Realy love the look of it!
Thanks, and i think im going to keep it spoilerless not sure if it would wreck the flow, what are your thoughts?
Discussion Starter #7
Re: Req's Rally Red
Wow, this is very nice! I am diggin' the vinyl work! I am having my roof covered on Wednesday. I really like the placement of the 2.7 on your front grille, very stylish!
...hope you don't mind if I barrow that idea in the coming weeks.
any thoughts of adding a clear coat on the vinyl? to give it that real CF shine?
Discussion Starter #12
Re: Req's Rally Red
Thanks, and yeah go for it i wouldn't mind at all :) And maybe, i almost like it better as a matte looking finish, but i've read that most clearcoat finishes dont adhere to well on the vinyl so you might have to experiment. Oh and the vinyl is quite water repelent as well, its almost as if it has a permanent coat of wax on it.
Re: Req's Rally Red
Car is coming along nice!
Keep the good work. I love red Tibbys
Discussion Starter #16
Re: Req's Rally Red
Okay so i got around to doing some work on the tib.
First up is is tinted tail lights, thanks to speedy's DIY and Renegade for info and tips
Isnt the best picture's but you get the idea :)
Also i tinted my side signal lights
Discussion Starter #17
Re: Req's Rally Red
And when cleaning my engine bay i decided to paint my horns to match my calipers
I have a few things planned for the rear, a few more pieces of 3M Vinyl to put on, will get some pics up when i have them on!
Discussion Starter #19
Re: Req's Rally Red
very nice! love the spoilerless look. keep it up
Thanks! Yeah i'm going to keep it spoilerless, gives it a streamlined look. Oh and i went with a sniper stage 1 as well, have the icebox in the mail, as well as the blower. TC is just finishing up the manifold and i should have it within the next 2-4 weeks if all goes well.
1 - 20 of 824 Posts
