1 - 13 of 13 Posts
I checked the Neo DIY but the pictures wont show up and the wires are different than what is being described.
Here is all the information you would need for the SAFC 2 for installing it.
IMPORTANT: DO NOT skip out on soldering the wires. This device relies on excellent connection and is robbed of that if you are lazy and do not solder. Be active and do the job right!
Make sure you disconnect the battery before installing!
Tools Needed:
Soldering Iron
Electrical Solder
Electrical Tape
Ratchet w/ 10mm bit
Phillips screwdriver
Wire Strippers
Zip Ties
ECU wiring Diagram
http://www.newtiburon.com/forums/showthread.php?t=161819
ECU Removal DIY
Thank you C-Shark
Set up process
hot wire sensor type, 1 in 1 out, set the throttle position going up
Thank you Dlanes for the Vid
http://www.apexi-usa.com/content/pdf6118.pdf
PDF User Manual
Basic Idea of Tuning Process
Thank you Korndog517 for the vid
Here is a trouble shooting thread that may help while installing
http://www.newtiburon.com/forums/showthread.php?t=180697
Good luck guys. Let me know of you have questions and ill help you out as much as possible
Re: DIY: SAFC 2 Wiring Diagram, Installation Guide, and much more
Wow not a bad set of videos. I'm going to fav these
quick question do I have to install so close to the sensor?or can I splice it closer? I figure since i have my car half apart for paint I might as well install the tuner now lol
Discussion Starter #6
No need to get close to the sensor. Just follow the pin diagram and directions on it then follow the vid for initialization. The other vid of the one titled safc II install, it shows the kid going into the engine bay to get to the sensor. This is not needed.
ok thanks for the input, do you have any pics of yours installed? like where you put them? can I just put all the wires right where the ecu is? i know on the DSM kits I used for my eclipse you can just wire them straight where they come out of the ECU but the problem is idk how sensitive this is to minor drops in voltages etc...
wow this is super helpfull thanks a ton
so is this for the v6?
thank you. also will this diagram work with the vafc cause i have it hooked up the same way but it doesnt read my throttle percentage.
1 - 13 of 13 Posts
