1 - 7 of 7 Posts
Ok so yesterday while i was attempting my SAFC install i got the ecu out but the wireing harness had no play in it whatso ever i couldnt even turn it to see which pins were which...is there a clamp somewhere or somethign i can do to get some room?
Former Staff
Re: SAFC trounble
Unfortunately, that sounds about right. You have to unplug the ECU from the harnesses and pull it out entirely. Then, lay on your back with your head under your dash, try to jam your hands up there and try to get as much play as you can to get your wire taps in there.
Re: SAFC trounble
i was liviiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiin when that thing wouldnt come out anymore...the only wire i could have done is the green ha
Re: SAFC trounble
just got through with my install. just lay under there and go at it man. Look at ur ECU for pin numbers if u need them. Good luck!
Former Staff
Re: SAFC trounble
SAFC install and Header install (on a V6) are the two most difficult installs... both simply because of a lack of space to work with.
Re: SAFC trounble
if you need a diagram i got one pm me.. but there are also some and i thought there was a diy too
Discussion Starter #7
Re: SAFC trounble
Has anyone tried removing the fan housing.....does it make this install ne easier?
1 - 7 of 7 Posts
