1 - 11 of 11 Posts
what is the safest boost to run with stock internals. say i was looking to push like six on the stock motor. am i going to kill the life of my engine? still owe a bunch on the car and i dont want to be blowing a rod through the block or something. thanks
search, search and then after that more search. Its been discussed MANY times. Safe is a relative term and really depends on your tuning skill and what sort of tuning method. With a bad tune she'll blow at 1psi, with a good tune you can run upwards of 18 psi safely.
dmdicks, just for my reference, what does 18psi equate to roughly on the i4 in whp? I realized i didn't know that trivial fact that other day...
new tiburon should buy you a pager dmdicks. That way when a thread like this pops up you get a page, and you can answer it, because you dont cut the person down, you give them a good answer and a solution for how to research it. Good job
couldnt say it better myself
I would say with a spot on tune a 100% bonestock Beta2 could do 350whp, with just a good tune 300-320whp should be easy. The key is in the tuning device and tuner using said device.
+1. one of the most helpful here!
1 - 11 of 11 Posts
