1 - 3 of 3 Posts
Alright I was thinking about getting my OBX header tapped. As most of you know OBX is too sh!tty to include a o2 bung and I'm sick of running rich. Now I remember reading that if you get the bung added to where the 2 meet 1 you will need to extend your sensor wire but this can also throw a code since of the amperage. Now what happens if you bung on 2 banks??? I image this will also throw a code but I'm wondering your opinion and the best way to do this...
Thanks
I put my primary in the bung provided on the mid-pipe of the OBX header, and I extended they second one behind the cat. If you CAREFULLY cut the loom around the wires, you CAN extend the second one behind the cat, and the primary as well.
Good luck, and carful with leaks, I am throwing a code because of one, Got to get around to fixing that.
1 - 3 of 3 Posts
