Hey man yeah those always break it’s for your ac to turn it on and off... yeah just strip the wires and put them together and you’ll be good... i highly doubt that’s causing your sensor fuse to blow... I’d check some over connectors and make sure... see if you have any engine codes it might help, if it fixes your problem then that’s great you dodged a bit of a bullet... if not you might need to change a bad sensor that’s shorting, from what I know your sensor fuse goes to your crank, cam, knock, sensor and I think your maf and throttle sensors, I could be wrong tho I’d have to check... but yeah I’m pretty sure it doesn’t go to your ac, that’s your ac fuse...
